stuck lug nuts
  • green 'n stinky
    • Nov 2007
    • 28
    stuck lug nuts
    I got a new set of wheels and tires to replace the rusty wheels and dry rotted hodge podge of old military tires that came on my land rover, but I can't loosen the lug nuts. I've been spraying PB blaster on them every so often for the past few weeks and I've tried a longish breaker bar. Is there a secret to this? More brute force? How about heat? I've been afraid of using heat for fear of damaging something, and I'm afraid I'm going to round off the nut or shear the bolt with too much force.
    Thanks in advance for any advice. I really appreciate all that I've learned since I joined the forum.
  • gambrinus
    • Jan 2007
    • 142
    IF PB Blaster won't break them lose, you may as well just order some replacement wheel studs right now to save yourself some time. You'll end up pulling the studs out at some point during this process. BTDT
    RW
    • leafsprung
      • 1008
      PCH offers fun quizzes on a wide range of topics. Animals, history, traveling and more. Test your knowledge and play our quizzes today!
      • BackInA88
        • 332
        Since the wheels are a mess anyway have you thought about putting a little heat to the lug nuts?
        Just don't heat up the studs to much.
        71 IIa 88
        01 D2
        • sven
          • 174
          You could try a cheater pipe on the end of the breaker bar.
          99 D1
          73 Series III 88"
          95 RRC LWB
          • galen216
            • 236
            On the truck I just bought I had to have about 2' of pipe on the breaker bar to get the lug nuts to break loose.
            Must have been a big gorilla that put them on....thank goodness I didn't discover how tight they were on the trail.
            74 SIII
            96 Disco SE-7 5 Spd.
            • yorker
              • 1635
              You can heat them - then hit them with PB, and repeat.
              Land Rover UK Forums
              • green 'n stinky
                • Nov 2007
                • 28
                thanks, I'll try again with more PB blaster, more leverage and some heat. I'll skip the shotgun, however.
                • Jeff Aronson
                  Moderator
                  • 569
                  Try heat on the nuts, quick and high, after you've drenched them in PB Blaster. The stuff works even better hot. I once had to use the handle to my Hi Lift as a pipe extention, and then jump on it, to loosen lug nuts.
                  Is the car running? Why not drive to a gas station, have them loosen them with an impact wrench and then tighten them by hand?
                  If not, the hand impact screwdrivers can take a socket. Whacking it with a small sledge will help loosed the nut. I know because I had to do that on mine recently.
                  Jeff
                  Jeff Aronson
                  Vinalhaven, ME 04863
                  '66 Series II-A SW 88"
                  '66 Series II-A HT 88"
                  '80 Triumph TR-7 Spider
                  '80 Triumph Spitfire
                  '66 Corvair Monza Coupe
                  • thixon
                    • 909
                    Have you tried an impact gun yet? Had this happen plenty of times. I'm 50/50 between a long a$$ breaker bar and an impact gun. While I like Ike's shotgun approach, I would'nt recommend it here.
                    Travis
                    '66 IIa 88
                    • green 'n stinky
                      • Nov 2007
                      • 28
                      I have a small, cheap air impact wrench and it didn't budge them. I didn't think to try the manual impact wrench; I may give that a whack, too. Otherwise, I might just take the truck to a shop (once I get my clutch fixed) and let them deal with it.
                      Thanks for all the suggestions.
                      • thixon
                        • 909
                        I've had one instance where I could'nt get 'em off with an impact gun. I made a breaker bar out of a peice of iron pipe about 6 feet long. Instead of using my arms to break them loose, I rotated the rachet so the bar was just above parrellel to the floor, and then stood on the end of the bar, and jumped up and down till they broke loose. It was a total PITA, and I was exhausted. I took about an hour. The possibility to royally F&*^ yourself up is an extreme possibility if you try this. Also, I broke two ratchets getting them all off. I got suckered into to continuing by the truck. The first couple I tried, came off pretty quick. The rest did'nt go so well, but I was deteremined at that point to continue. I'm not recommending it, just letting you know I did it, and it worked.
                        Good luck.
                        Travis
                        '66 IIa 88
                        • green 'n stinky
                          • Nov 2007
                          • 28
                          Well, the combination of some heat, PB Blaster, and a 4ft jack handle over the breaker bar did it. I broke a socket extension and it was a bit disconcerting each time the nut broke free, but it worked.
                          Thanks for all the suggestions!
                          • Jim-ME
                            • 1379
                            Remember to put a dab of never seize on the lugs when you put the nuts back on and you'll not have as much trouble next time.
                            Jim
                            • I Leak Oil
                              • 1796
                              There's always that splt second where you're not sure what made that horrible "CRACK"! Was it the nut, the stuck, you're tools or YOU?!
                              Use a little anti seize when reassembling and never go through that again.
                              Jason T.
