I am contemplateing replacing my spring (not parabolic) bushings in the near future. Any recommendations? I do mostly road (and a little trail) driving. Thanks.
Best bushings?
The stock ones are nice and will probably last another 30 years. If you do go poly I would suggest greaseable bolts ($$) from GBR or elsewhere.
JaredVisit The Wandering Hippo (my 109 S2A Ambulance). -
Originally posted by KingSlugThe stock ones are nice and will probably last another 30 years. If you do go poly I would suggest greaseable bolts ($$) from GBR or elsewhere.
Poly bushings can not stand heat well. They become soft and disintegrate. Standard poly bushings usually comes with a lube, but that lube doesn't last all that long before you hearing the standard dry poly bushing suspension squeak. Washboard roads case nearly constant motion of the poly bushings and the friction from dry moving bushings builds up heat ... and they die.
The theory behind greaseable poly bushings is that you can easily regrease them without any disassembly. So if you remember to lube them you don't get suspension squeaks and the friction stays low enough that the bushings don't come apart from excess heat. Neat huh!
Here's some pictures of the greasable poly bushings that Great Basin Rovers sells:
Sasquatch runs poly bushings in his truck. So do Martian men, the jolly green giant, and most Republicans looking out for the common man.
If there’s on thing that doesn’t seem to fail on Series trucks, it’s the spring bushings. And if I’ve seen one aftermarket part that doesn’t seem to live up to its promises, it’s poly bushings. I was following a RRC once that had new blue poly bushings in his truck and after 30 miles in the Anza-Borrego desert all four of them had self-destructed. He looked like Hansel and Gretel leaving a trail of blue bread crumbs behind him.
Jared is right….The originals lasted 30 years, the replacements should too. Stick with OE in this case.
Sorry TeriAnn, I disagree with you on this one.Comment
I have a set of nylatron (similar to poly) on the track/autox car, and the manufacturer has extensive experience with these on that sort of vehicle, since around '01. They advise that they be lubricated every 1,500 miles. And the nylatron is supposed to be a bit less sensitive to poor lubrication than regular poly.
You can buy grease zerks and drill and tap many of the mounts these are fitted into, but I am not sure if all of them on a Series truck can be.1965 Series 2A 109 pickup dieselComment
I was about to say that my rubber bushings were mostly disentigrated and the inner steel tubes were loose, but then I remembered my stock frame bushing were over 30 years old when I replaced them in the early 90's.
Originally posted by MercedesroverSorry TeriAnn, I disagree with you on this one.
Besides life would be way too boring if everyone were to agree with everyone else.
I do agree that stock bushings should provide the longest service life though. I just want a bit more movement out of mine.-
For me it's a toss up. I really don't think I'd notice any difference in ride quality but I think I'd rather change 50 sets of poly bushings than go through the hell of changing the stock ones on a 40 year old vehicle again.
Jason T.Jason
Originally posted by TeriAnnI just want a bit more movement out of mine.Comment
Originally posted by Jason T.For me it's a toss up. I really don't think I'd notice any difference in ride quality but I think I'd rather change 50 sets of poly bushings than go through the hell of changing the stock ones on a 40 year old vehicle again.
Jason T.Comment
Bushings
I dont think the quality of the replacement rubber bushings is as good as the originals Ive had several fail within a short period of time (2-3 months) . And had a set of RM rubber spring bushings fail in a matter of hours in moab. Since then Ive jumped onto the poly-bushing bandwagon. Mostly due to ease of replacement. I can replace a poly bushing in 20 minutes without firing up a torch or sawsall. I could even do it on the trail if need be. If you get quality poly bushings, they last a good while. I dont mind replacing them, but I hate replacing the rubber ones.
Articulation is for trucks without lockers!
Originally posted by MercedesroverArticulation is for trucks without lockers!
I reserve mine for when I think I otherwise might break something or might fail a climb with a treacherous back path or when I get stuck.
Hurry up & get the bulkhead on your 109 project! I want to see more pictures!!
Please ...-
Originally posted by leafsprungI dont think the quality of the replacement rubber bushings is as good as the originals Ive had several fail within a short period of time (2-3 months) .
Don't you have one of those ball joint removers? I used one of them and a 3/4" impact with a pretty good degree of success.Comment
Has anyone used the Bushwaka bushing replacement tool from DingoCroft? I have often thought of buying one then renting it out to series owner to spread the cost and reduce the anguish.
Jared
Part number: ZZBSWK01
Application: Series I, II, IIA & III, SWB and LWB.
N.B. non-specific photo - BSWK01 comprises 10 separate parts. Description:is a tool specifically designed to remove and insert "metalastik" type suspension bushes, without the aid of a press, in one quick and easy operation. It is ideal for all types of workshop from Army posts to Ambulance Services, Land Rover main Dealers to Local Specialists, The Royal Mail to Hebridean Quarries.
Fast one man operation, with component still in situ, the new bush pushes out the old one whilst being inserted.Visit The Wandering Hippo (my 109 S2A Ambulance).Comment
Originally posted by leafsprungThey are great at wedging the bushings in the frame.Comment
