ARB bull bar questions
  • adkrover
    • Jan 2008
    • 206
    I have a Series 2a with an ARB deluxe winch bar installed and was hoping someone could help with a few questions.
    1. It came to me from the PO but he hadn't installed the turn indicators and they are not to be found. Does anyone know where to get replacements?
    2. I want to install a Warn XD9000 on it but the ARB website says you need to order a spacer. Anyone done this before? Is it something I can make myself? I have a pretty good welding setup.
    Thanks
  • leafsprung
    • 1008
    Id sell the ARB personally and make your own bumper.
    1) you save money for other goodies (like getting an 8274 instead of an xd9000)
    2) you have the welder already
    3) modern bullbar looks goofy on a series
    • adkrover
      • Jan 2008
      • 206
      Leafsprung,
      Thanks for the comments but none of them addressed my questions. I personally think the bar looks very good on the truck and for where I drive, I need the full frontal protection that it offers me. If I built one Myself it would look almost the same. I have the original bumper if I ever change my mind about it. An XD9000 should be more than enough power and speed for my needs. Like I said, thanks for the comments anyhow. I've attached a few photos.
      • leafsprung
        • 1008
        Different strokes. . .
        Im sure you can order the lamps from an ARB stockist/dealer. As for the spacers, buy the winch, measure the gap, make the spacer.
        • I Leak Oil
          • 1796
          Clean looking truck. I have to agree with Ike that the ARB doesn't look quite right on a series truck, but if you like it that's all that matters. As for the lights, if you want ARB parts I'm sure our hosts or any other ARB rep could get them for you. If you look around you can probably find an aftermarket set that works with some modification. I bet a set from a defender would work.
          Can't be sure but I think the spacer is just to lift the winch up a little. Like I said, I can't be sure though so you're better off just asking an ARB rep what the special spacer does.
          Jason T.
          • Willard
            • Jan 2007
            • 52
            Aside form not liking bullbars on a series myself. i think it looks funny . If you have a welder and any fab skills at all, get the winch, and test fit it, if you need a spacer make one.
            Also from the looks of your you have 2 options to mount a winch. so i think you might be ok.
            For the turn signals. Should be the same on every ARB. Myself i would fill in the holes (weld a new plate on then and smooth it out) as they will look really odd on a Series 2a.
            • PH4
              • Jan 2007
              • 375
              I believe our host makes a product that mounts the turn signals on top of the fenders and looks very series like. I would check out that option.
              • yorker
                • 1635
                I agree an ARB Defender type bull bar just doesn't look right on a Series particularly a IIA but if you like it and it fits your needs well then you should be happy with it. Re-mount your existing signal lights atop the wings with an L shaped piece of aluminum or something akin to that so they clear the bar.
                Land Rover UK Forums
                • KingSlug
                  • 177
                  I have to agree with that the ARB looks silly on a S2, but Max over at Guns and Rovers has one on his tan 109.
                  This is the bumper I have always wanted on my ambulance.
                  Jared
                  Visit The Wandering Hippo (my 109 S2A Ambulance).
                  • AlaskaRover
                    • Mar 2008
                    • 2
                    I have this in the front of my 109. I don't really like it. but it's good moose protection. I have never had it off, but I'm guessing it wieght a few hundred pounds.
                    Duncan
                    Fairbanks AK
                    • LaneRover
                      • 1743
                      I could be wrong but I think that he is wondering about putting lights in the 'holes' that are in the bullbar that are built for lights.
                      • xsbowes
                        • 258
                        http://www.arbusa.com There is a locator for the nearest dealer, they should be able to order you the correct ones. You might need the part number of the bumper.
                        Stacy
                        Stacy
                        Motta S.A. Italy
                        • Les Parker
                          • May 2006
                          • 2020
                          Lamp kit for ARB
                          Ref the lamp kit, our hosts have these available, from stock:-
                          3500080 Lamp kit Current price $38.12 for the pair.
                          Please advise,
                          • adkrover
                            • Jan 2008
                            • 206
                            OK folks. So I did find someone to sell me the ARB replacement lamps. We'll see if they are the correct ones when they arrive. I have the stock signals located on the wings and they work just fine so I don't NEED the ones on the bumper. My first thought was to cut the holes larger to accomodate fog lights but then decided having the extra signals made good mechanical sense. Redundant maybe but here in New York there are very strict annual inspections and the troopers love to pull people over for broken lights just to see what else they can get you for.
                            As far as the looks, I'm still a firm believer that it looks good on my truck. It will look even more purposeful once the winch and driving/fog lights are installed. Like I said, I also need the protection of a full frontal bar as I am also in heavy deer and moose country. The roads I venture out on are primarily unused logging roads so there are plenty of low lying branches and small trees to deal with as well.
                            Thanks for the feedback and remember, even an ugly child is loved by it's mother.
                            • LaneRover
                              • 1743
                              But wouldn't a heavy deer be fatter and not cause as much damage....
