I have a 67 series with an ignition problem. I've replaced the battery and the solenoid (new part is land rover) as well as the ignition switch.
When I bridge the solenoid, the motor turns over. I can't for the life of me get the new ignition switch hooked up properly.
The new ignition switch is part 5667 - ignition switch solenoid type. It has 4 connections - three doubles and a single. One of the doubles is smaller than the other two.
The old parts were a ford solenoid and an ignition switch which doesn't correspond to anything in the parts catalog.
I have three wires - 1 is from the battery, one from the coil and one for accessories (at least that's the wire I pulled off the "ACC" of the old ignition).
Cheers,
Marco
Cheers,
Marco
