I am in the process of replacing both swivel balls because they leak due to corrosion. I want to have everything on hand before I start and will be pre-assembling as much as possible to save lift time. I have several questions.
1. How can you tell the left swivel pin housing from the right swivel pin housing?
2. I know that the axle half shaft roller bearing presses into the axle housing end of the swivel ball. The RN cat. referrs to a retainer collar for the bearing and a bearing distance piece. Are these parts mounted on the axle half shaft or do they get pressed into the swivel ball with the bearing?
Thanks,
Jim
Thanks,
Jim
