What causes a vehicle to keep wanting to run even after you have turned it off? I keep having to stall the rover to get it to cut off. Now, there are a few items adding to this problem.
1.) Carb has not been thoroughly cleaned...even though it looks pretty clean.
2.) Exhaust has a leak somewhere underneath
3.) Would the timing be off?
When the rover runs, it seems to drive fine...however I have to keep the choke pulled out just a little bit for it to run smoothly.
Also the exhaust gets the occasional pop and sputter while idling.
The spark plugs are new and gaped properly. The plug wires are also new. Fuel is clean and a can of Seafoam has run through the tank.
With that said, would you think this is a timing issue or just a mix of air getting into the exhaust and a dirty carb that has not been tuned properly?
