Shucks...Just when things are going good. Have been enjoying this '73 88 as a fair daily run about. On the highway cruising at 60-65mph, on my way to Cabellas' when the speedo bites the dust..
Have had the instrument panel off twice before, once to fix the washer switch, then of course once an hour later to reconnect the speedo cable.
royal pain in the axe(do you just pull the steering wheel, and with what type of puller?).
Pulled the panel today and it appears that the tapered end of the cable male end that comes from the back of the speedo, has broken off into the speedo cables female receiver..
Can you order that as a part? Do you just get a new speedo?
This is a clean low mile dash- under 23,000 miles...nice glass and everything is intact(well not the cable end).
Running the origonal 15's was thinking of going to 16's this spring/summer.
Any ideas, help would be appreciated, yours in Brittankia
Bren
Bren
