I am trying to change my '59 Series II from the Series II thermostat housing/thermostat to the IIa-III version. I was having all sorts of overheating issues, running very hot overall and suspect from the behaviour of the temperature gauge on cold days that the old thermostat was stuck partially open. (new radiator, hoses, good low mileage water pump) Two of the three bolts twisted off while trying to remove the old housing and it still will not budge. Tried penetrating oil on the stuck bolts and then some not so gentle persuasion with a fine wedge and a hammer trying to lift the housing from its lower face, still no movement. Don't really care about the housing itself, as I'm trying to replace it, so I drilled out 1/2 the length of the offending bolts to remove some binding with the bolt's shank and hit it with more penetrating oil. Still nothing. I am hessitant to drill out the bolt down to the top of the threads as I would like to have something to grab onto to try to coax the bolts out of the head when I get the housing off. Any good ideas for removing the housing? Heat? a bigger hammer?
Any help would be appreciated.
. Bought solid carbide drill bits (a bit expensive but truly phenomenal; drilled the extractor easier than my cheap bits drilled the bolts!) and removed the extractor
