god ludwig running again
turns out the PO had not installed the gear on the distributor right and it had jumped timing 180, well we pulled the dizzy and dad saw a gear in the dizzy hole and pulled out the gear/piece that fits to the bottom of the dizzy, put it back on the dizzy and it would not fit easy so he got the small persuader
aka the small ball-peen hammer, a couple of taps and it fit proper
stuck the dizzy back in and set the timing and he fired right up, and the miss is gone now too and i would almost bet the knock is gone too but we ran out of time so we could not check that
thank you, everyone for your help diagnosing Ludwig's problem
aka the small ball-peen hammer, a couple of taps and it fit properstuck the dizzy back in and set the timing and he fired right up, and the miss is gone now too and i would almost bet the knock is gone too but we ran out of time so we could not check that
