I have a silly question about the coil on my new 1964 Series IIa 88". The guy who was restoring it was not really knowledgable and I have found several simple mistakes he made in putting things together. Currently the coil is mounted upside down in the engine compartment (connections pointed down). My mechanic friend says this is bad for the coil and will eventually lead to failure. Currently everything works fine, so should I bother turning it "right side up" or is that just an old wive's tale? Is there a difference in the way the coil is mounted?
Any advice would be appreciated.
