Any suggestions on refurbishing the brake and clutch pedal brackets? They are completely stripped down, but the retaining pin holding the shafts is not going to come loose in my lifetime. Is it advisable to chem wash the brackets with pedals in place? Or, should I just treat the rust and hope the internals are good to go? Clutch bracket cover pretty rusted and is a good candidate for a chem wash, had to drill off the screw heads. I'll retap the bracket screw holes. I'm thinking that the pins will be easier to deal with if the units are washed.
Going to Phoenix in two weeks to drop off bulkhead for bath.
