I recently replaced most of the seals and gaskets on my transfer case and filled it up with some nice fresh Lucas oil. No leaks and it sounds great! In fact, I don't really hear it any more unless I'm really pushing speed limits on the freeway. The problem is, when I let off the throttle or put it in neutral on the freeway there is a new horrible sound coming out of the drive train.
If I keep the throttle down, there is no rumble. If I decelerate (using the engine compression) there is no rumble. It's just when there is no motive power going through the drive train that I can hear this horrible sound.
Now I've tested this sound a little bit and it seems to only start showing up around 45 and gets progressively worse the faster you go. When I first noticed it, I was going about 70 and I thought I had blown the rear end.
It sure sounds like it's coming from the rear diff. I've checked all my connections on the drive shaft and wiggled everything around but nothing looks obvious.
Could it actually be coming from the transfer case and fooling me? Since that is the last thing I touched it would make sense that that this is where it is coming from but it clearly sounds like the rear diff. When I drained the old oil out of the transfer case, there was a good amount of shavings in there but nothing that had me too worried.
I'm going to drain the rear axle tonight and see what the oil looks like. If it does appear that I've got lots of shavings in there, I guess I'll know what it is.
Till then, does this sound familiar to anyone? Is there a common bushing that lets go in the diff or transfer case?
I did have the diff out a few months ago to get the snapped end of a drive shaft out. Maybe there were some shavings/parts left in there that could be playing havoc with me now...
