Have been trying to correct an erratic idle in an ex-mod 109 with a 2.25/Zenith. Have rebuilt the carb, timing is ok, valves adjusted and no vacuum leaks. A friend mentioned the PCV valve (looks original and the diaphram is suspect) and thinking they were a few dollars went to order one, surprised (very) at the cost of a replacement PCV. Has anyone used an aftermarket, and if so do you have the manufacturer and part number? Thank you very much
PCV question
Originally posted by svenIm pretty sure you can just buy the PCV diaphram for around $15 instead of buying the complete valve.
According to the Land Rover factory maintenance schedule the valve should be cleaned and diaphragm inspected every 8 thousand miles (every other 4 thousand mile maintenance).
The factory maintenance schedule is your friend.-
PCV
To check and see if it is the PCV disconnect it and plug the vacuum line. The vehicle should then run OK if the PCV is the only problem.THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HTComment
Originally posted by siii8873To check and see if it is the PCV disconnect it and plug the vacuum line. The vehicle should then run OK if the PCV is the only problem.
When you are done doing diagnosis it would be a good idea to keep the PCV connected. It helps keep the inside of your engine cleaner and it doesn't degrade performance when properly maintained.-
