I need to clean up my rear tub 1/4 panel on my 109. It is an ex-mod that obviously saw some damage and as a result has alot of dings and dents just behind the door. None of them are very severe although it looks a little nasty.
I thought that the best cure was to sand it down to metal, and just skim coat it with bondo to flatten out the pimples.
My question is what grit of sandpaper should I use? Bondo recomends 80 grit, but I am concerned that I will score the aluminum. I just redid a hardtop using 180 only to remove 4 coats of paint, and although not completely done yet (just primer) it looks very nice and smooth.
Do I need 80 for the bondo to have something to stick to, or should I use the 180?
Thanks in advance,
pics of the beast on the above link
Thanks in advance,
