these are the pads I need for the rear of my 88, correct?
Quick Brake Question
'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesTags: None -
nevermind - they are.
Question though - I will need extra fluid after I change out these pads, correct? and it can only be the Girling stuff? thanks a lot'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in pieces -
You can also use Castrol GTLMA as well. Grab yourself a couple of pints and flush the system out while you're at it. Brake fluid absorbs water and gets pretty nasty after a few years. Keep fresh fluid in there and your master and wheel cylinder will last much longer.Comment
thanks! can I get that Castrol at an auto parts place, or should I start looking around online right now?'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesComment
thanks guys. I replied to my order email from RN to add a bottle of Girling. HOpefully that works!'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesComment
