Below is a post I put on another board. I thought some of you here might want to see the progress. This was done last Saturday. I won't be able to work on it again until next weekend, so I'll update it then.
"I got started on my Bulkhead yesterday. As most of you saw, really the entire lower section (footboxes and doghouse) are shot. Mostly because the previous owner did a half-arsed attempt at fixing things. As you'll see, he was probably the greatest welder I have ever known (to be read with much sarcasm).
I started by drilling out the spotwelds on the driver side footbox. To do this I just simply used a 5/16" drill bit, and punched straight through. I did'nt worry about making a hole all the way through because I'm using new footboxes, and will have metal to weld to for my rosette welds. Where I did want to re-weld to original metal, I used a harbour freight spot weld remover. Cheap and effective.
Below is what I ended up with after drilling for a while.
There is a stiffener across the top of the doghouse, on on the inside top of both footwells. On the driver side (still had original foot box), this was not problem, I just drilled out the welds. On the passenger side, it stunk. The metal was in bad shape, and the previous owner simply welded around the edges when he tried his new footbox repair. See below.
I was finally able to remove the piece by grinding off his weld.
Sadly, the passenger side end of the stiffener is shot.
So, a quick pass of the plasma cutter, and the bad metal is gone.
I'll clean this up later, and make a new piece to weld in. I couldnt do it today, because I did'nt have the right gauge sheet laying around.
I went ahead and cut out the other footbox, using the plasma. Remember, this was the side that the previous owner had tried to repair, so I was really just cutting through his bad welding job, and blowing off bondo with the wire wheel.
Here it is, no footboxes.
Notice the missing tab above where my had is. It was badly rusted, so I cut if off. I now had to remake, and weld on a new tab.
To make the tab, I measured the length, and used the shape of the good side to mimmick the curve. I then used a cut-off tool to cut out the shape.
If you don't have one, I can't recommend it enough. See below.
To cut out a shape using this tool, draw your shape, then cut a small groove in the metal first. The groove will provide the guidance you need to cut through the metal later. See below.
Before the piece is welded:
And after:
I then went to work on the door posts. I cut them off straight with a recip saw when I was removing the foot boxes.
I used a new set of door posts with the feet already welded in place. I used the j-nut holes for mounting the wings as a reference point, to make sure I was at the right hieght.
I then bolted the bulkead to the frame. Every thing measured out height wise (which was a big relief).
I hav'nt mounted that foot box you see above yet, its just sitting in place.
The only bad news is that I think the bottom sections of the dog house are shot. I may go ahead and fix it, but right now I'm leaning on just buying the center repair piece from RN.
My plan from here is to attach the footboxes and center section to the upper section using sheet metal screws. This method draws the assembly together tightly, and allows for a very good fit. Then I'll tack weld the assembly together while its bolted to the frame, and remove the sheet metal screws. Then the fun of welding up holes begins. Yahoo!!!!!!!!!!!! Not bad for a Saturday afternoon.
I was brief here on purpose. If you see anything you have questions about, ask away.
To be continued....."
And after:
