Just in case anyone's wondering how to make a patch for thier rotten bulkhead in the area of the fresh air vents, here's how I did it. It DIDN'T involve a huge press and dies to form the vent seal channel, just a little bending, and a lot of MIG welding, grinding, welding, grinding, welding, grinding....:
Photo #1--Used a template and cut out straight and flat sections of vent channel.
Photo #2--Side view of photo #1
Photo #3--Took small pieces of sheet and rounded them to fit the corners. Same for the inside corners (not shown). Welded it in then cut off excess metal. The flat 90 degree outer flange was then welded in (not shown).
Photo #4--Vent seal channel was welded to back of bulkhead patch section I made/bent/welded together
Photo #5--Mostly-complete unit sitting in place for a test-fit.
Not shown are some reinforcing pieces in the back that are simple to bend and weld in, that replicate the factory sections.
There's probably a better way to do it, but this is what worked for me. Now if I could only figure out how to post the photos (not thumbnails) and put captions under them like everyone else does on this board, I'll be all set!
