i dont know where these two wires go. this is off the wiring harness you unplug to remove the engine. this harness is held to the oil fill tube, and the waterpunp by metal tags. the second pic shows the color coded wires that are part of this engine harness. the one plug is larger than the other (flat spade) and the other falt female spade has a platic weird outer casting around it. hope the pics will help you help me. thanks
does this plug in to the box in the first pic??
