Anyone have any advice as to the best way to remove the seals and glass on the corners of the pickup top? Started to Sunday but did not want to force it. I assume their is a "technique" to remove them. Green bible does not adress.
Pick up top rear quarter panel windows
I'm assuming that you mean the stationary windows that are in the corners. Once you pull out the rubber center fill strip, you should be able to pop the glass out with the extra room the filler strip was taking up in the seal. You'll probably need a wedge of sorts to slip the window past the rubber lip. Use plastic or wood as a wedge, not a metal screwdriver and use soapy water as your lubricant.
If you can't get the rubber to flex at all, then you might need to replace them.
By the way, after doing this job you will realize at least one thing. You can't lock your keys in the truck no matter how often you lock your keys in the truck.Comment
