well got the 4wd transfer case put in over the weekend and took ludwig for a drive up our hill today, with a 5 gallon gas tank, the passenger gas tank has decided to leak, so i pulled it and am fixing it
well ludwig is no longer a comedian he no longer knocks, so it could have been something in the original transfer case
now to fix the leak coming from the transfer case and pull the bolt that i snapped tightening it down, of course i will have to drop the pan and drain the oil for one damn broken bolt
he is leaking from the rear hub area where the oil seal is on the transfer case, he is on a fairly steep hill and might have gotten over filled, he is only dripping now though so i figure it is just a normal land rover leak
