twin tanks
  • PH4
    • Jan 2007
    • 375
    twin tanks
    Had to remove the right side fuel tank from my 1962 IIA. You had to remove seat to fill up. I see the proline underseat version is made for filling from fuel extender mounted to side of 109 body. The only other tank I see comparable to the one you fill by removing the seat RN has listed for $800. Anyone know a source for one you can fill under the seat(less than $800)? Options?
  • TeriAnn
    • 1087
    What are you driving a 109 five door station wagon?
    British Pacific offers an after market auxiliary fuel tank, #TK101. I believe the current price is $279. At that $800, RN's auxiliary fuel tank is very likely to be a genuine Land Rover part.
    Teriann Wakeman_________
    Flagstaff, AZ.
    My Land Rover web site
    • scott
      • 1226
      i put a regular tank under my driver seat. cut a hole in that sill in front of the bulkhead. routed a vent line over to the othe tank and just T'd it in to the original tank's vent. then i found a rubber cap at a hardware store, i think it was a 2 1/4". it fits tight enough that i have to use a pry bar to get it off. i just push the back of the seat forward to get to the spout. eventually i want to put a regular fill spout and cap just like the right side.
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
      • PH4
        • Jan 2007
        • 375
        It is a 1962 109 Regular former FFR, however, the chassis does not appear to be a military (no squared rear). I had two tanks (one under both front seats) with the land rover fuel selector on the bulkhead.
