Please see photo. kind of worrisome when you think about a spark somehow getting into the rusted hole. No idea how long I drove around with it like this but did not occur overnight.
Gas tank
Why, WAXOYL 120-4 is the best.
Or Marvel Mystery Oil, as a substitute.
LesLes Parker
Whew....
and by whew, it means glad you found the hole, not whew from the gas fumes.
Your worry would not be from a spark entering the hole, but the vapors emitting from it and a spark igniting those vapors (including static electricity). Most folks have no idea how powerful and explosive fuel vapors are until too late.
Good luck!
Jeff64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
I'm sure the tank can be repaired by a good radiator shop. Soaking the sender in Mystery Oil may work. I guess I was lucky, mine came right out!! If you have it repaired, have the shop shot pean the inside and seal it before install. Good Luck !!'94 D-90, '59 SII 109 RegularComment
personally I dont think its worth repairing. replace it. Dune runner, where in OR are you? Im in Eugene/SpringfieldComment
i just bought a new oem 88 tank, you pay the shipping and ill cut the neck off and mail it to youOriginally posted by WoodslugAssuming you are going to trash that tank, I would love to buy the filler neck off you.
TedComment
Might try the fix mentioned in this post by 917601: http://www.roversnorth.com/forums/showthread.php?t=3825
I have used the POR 15 products myself and have found them to be good performers!'94 D-90, '59 SII 109 RegularComment
