I am looking for a good rack to install on my 109. My garage door is exactly the right height as long as I have a full tank of gas and the rear spare mounted so adding a permanent rack is not an option. I don't park the truck in the garage on a regular basis but it is nice to bring it in for maintenance and repairs. I'd like to find a 3/4 or full length rack that I can easily remove by myself without too much trouble. Any suggestions?
Good roof rack suggestions?
even a light wieght aluminum rack is going to be hard to handle by yourself. i don't have a rack yet but my plan is a simple block & tackle in the tree next to my drive. then i could just pull under the tree hook up, disconnect the supports, pull it up, tie it off, drive into the garage and then go back and lower the rack to the ground.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
'07 LR3 (Series Recovery Vehicle) -
Good decision not to go with a brownchurch or other type of more permantent rack as when the seams on your tank DO leak you'll be SOL!Originally posted by adkroverMy garage door is exactly the right height as long as I have a full tank of gas and the rear spare mounted so adding a permanent rack is not an option.
On a more serious note, I'd imagine you'd be better off with a cross bar and basket type of system so you can remove the basket without removing the roof mounts. Unless you really "need" it you're better off without the roof rack all together though.
Jason T.Jason
I figure on using either the winch in a tree or my compact backhoe to remove the rack so no problem on that. I also figure on the crossbar/basket type because of the easy gutter mounts. I was just hoping to find someone who could recommend a good quality, solid unit that has the same kind of look as the Brownchurch and other older style racks.Comment
Unfortunately I don't think you'll find one that "looks" like the brownchurch through the regular sources. You could build one or have one built for you.
If you do we'll need pictures of course!
Jason T.Jason
