So what is the minimum work needed to install a High Ratio Transfer case into a IIA with a welded in cross member?
Can you leave the main gearbox in and unbolt the xfer case?
Do you lift it out through the cab? Do you have to take out the seat base?
What, if anything gets taken off of the stock xfer case?
Any special tools needed?
This will be my first time tearing out part of drivetrain and I'll be trying to get this done in one day. Thanks for any advice.
