The best thing is to take it off the truck and strip it on the bench and then follow the manual. The only gotcha is that all the ball bearings will fall out of the burman nut at some point. It helps if you only open it up on a clean, contained area. Doing this over a dirty garage floor among years of acummulated crap will have you spending hours hunting them down and wondering if you got them all. Count the balls out and count them back in again. When reassembling coat each ball ingrease to hold them in position while you thred the nut on the scroll.
Oh and pay good attention to the condition of the ball bearing races. If lubrication has been questionable they can often show spalling as a sign of fatigue failure. If present, this pitting will be obvious when you look.
Cheers
Gregor
Cheers
Gregor
