Fuel gauge reads Backwards
  • dunerunner
    • May 2008
    • 110
    After a tank replacement, I replaced the old sending units with original LRP senders. The gauge now reads backwards. Not so bad, as long as you remember that if the gauge reads 'F', its empty!!
    Truck is a '59 series II converted to neg. earth.
    Parts house techs and my wrencher have been working this for a month without a fix.
    Any Ideas??
    '94 D-90, '59 SII 109 Regular
  • graniterover
    • 167
    Is this a trick question? Swap +/- leads on back of gauge?
    • leafsprung
      • 1008
      The problem is the new and old sending units opperate opposite to one another. So as the contact moves along the rheostat in the unit the resistance is opposite to what it would be on the original. You can swap gauges or turn the arm on the float around so it moves the other way. Swapping the wires wont likely make any difference.
      • dunerunner
        • May 2008
        • 110
        Found out the gauge only works one way. The coils are biased against each other and without tearing into that, making the senders operate opposite is probably the ticket.
        What gauge (Year/+ or - earth) would I swap with? Because that would be so much easier!!!
        Issue is one of the custom tanks is welded into the truck. Therefore, drain, cut it out, pull sensor, reverse float, re-install. just remove the left front wheel and disconnect the shock to manuver the tank enough to extract it from the frame. The tank under the right seat is bolted in and relatively easy to access.
        Thanks!!
        • leafsprung
          • 1008
          The later gauges post 67 will read correctly but the gauge wont fit into the early 3 way cluster without some sugery/trimming. A late cluster with the late gauge will fit into the early dash. Why is that tank welded to the truck???
          -IKe
          • dunerunner
            • May 2008
            • 110
            -IKe
            Weeell, That was how the farmer who had the tanks built mounted them in 1967. When I had the tanks removed and replaced the passanger side with an original tank, my wrencher re-installed the old right side tank under the driver and welded it in instead of fabricating a bolt in bracket for it. Once it's done, it's done!!
            Thanks for the heads up on the late cluster, know where I can get one?
            Scott
            • dunerunner
              • May 2008
              • 110
              Found a gauge at our benefactor $245.....Ouch!!! I wonder why parts didn't ship the right sending unit in the first place? Are they still available for the series II?
              • dunerunner
                • May 2008
                • 110
                OK...Guess that's a fair price for a guage? I'll authorize Performance Autohaus to order it. $%$#
                • LaneRover
                  • 1743
                  Mine reads backwards and I look at it as a small type of theft deterent. Eventually they won't realize that they aren't running out of gas! ;-P
                  I figure that now 'F' stands for Fill the tank and 'E' means I have 'Ever so many miles to go'.
                  Brent
                  • leafsprung
                    • 1008
                    Take a sharpie and black out one of the legs on the E then take some white out and add a leg to the F
                    • dunerunner
                      • May 2008
                      • 110
                      Leafsprung - Thanks for the gauge source in your PM.
                      • dunerunner
                        • May 2008
                        • 110
                        Changed gauges!! Bought a Series III '67 - '84 Lucas LU/BF6106-05 Fuel Gauge ($66.15 at RDS inc. shipping). The gauges are identical with the exception of the meter face plate. I swapped face plates and bent the indicator (needle) to fit the concave arc of the old faceplate and no trimming of the trio gauge assembly. Thanks again to Leafsprung for the help.
                        • 1961 109 WAGON
                          • 227
                          mine did the same thing, read the wrong way. i talked to ike, he gave me instructions on how to modify the sender so it reads correct. then it was a matter of re-bending the rod so it matched the gauge on the dash when it moved. took about an hour to modify the unit and re-bend the rod.
                          • leafsprung
                            • 1008
                            Nathan,
                            I have a tailgate for you.
                            -Ike
                            • pvkd
                              • 118
                              I like this suggestion !
                              1971 109 Safari Wagon (1 ton chassis)
                              1995 LWB Range Rover Classic
                              1997 Defender 90 (repaired at last)
                              2001 P38A Range Rover
