I posted this on another thread, but just wondering if anyone looking here has seen this vehicle for sale. See below:
1967 Landrover Series II; 88” wheelbase, Safari top, 54,500 original miles; Landrover Limestone original and restored color.
I have driven the vehicle about 100 miles since rebuild. Engine runs very smooth, 60 psi oil pressure.
Rebuilt Items: (All parts from Rovers North)
Chassis
New Galvanized Chassis
New left front fender
Rebuilt firewall, new footwells (replaced all rusted sheet metal)
New fuel tank
Body completely disassembled, painted, and reassembled
New rubber seals between roof and body
New weather stripping around all doors
New sliding window seals driver, passenger, sliding rear compartment windows
New Safari roof spacers
New galvanized splash guards
New galvanized front bumper
Engine
Rebuilt Rovers North engine (British Military overhaul with dyno test)
New engine mounts
New Clutch
Rebuilt slave cylindermaster cylinder
Electrical converted from generator to alternator, positive ground to negative ground
New voltage regulator
New coil
Radiator boiled and cleaned
New radiator hoses
New fan belt
Exhaust
Complete new exhaust system: pipe, muffler, hangers
Suspension
New leaf spring assemblies (4)
New shocks
New check straps
Brakes
New brake shoes all 4 wheels and emergency brake
New brake cylinders all 4 wheels
New brake lines (complete)
Rebuilt master cylinder
Interior
New upholstery all seats and seat backs
Electrical
New wiring harness
All lights are in working condition except turn signals (needs flasher or work on turn signal itsel)
Drive Train
New wheel seals (all 4 wheels)
New wheel bearings all 4 wheels
New output shaft seals, both differentials
Rebuilt knuckle joints in both front wheels
All gear oil replaced with AMSOIL synthetic gear oil
Warn hubs
New u-joints
New transmission mounts
New boots on: drive shaft, transmission shifters, clutch shaft
Things To do:
Vehicle is equipped with stock 15 inch wheels and tires (might be original tires). 16 inch wheels and tires would be better.
Need to finish interior upholstery; roof liner and door liners
Need to install heater hoses from engine block to heater
Need to install defroster hoses from heater to windows
Need to work on windshield wiper motors
Need to work on turn signal switch
Chassis
New fuel tank
Engine
New engine mounts
New Clutch
New coil
New radiator hoses
New fan belt
Exhaust
Suspension
New shocks
New check straps
Brakes
Interior
Electrical
New wiring harness
Drive Train
Warn hubs
New u-joints
Things To do:
