While driving around town over the 4th of July, my '65 Dormobile died at a stop light. A few minutes of troubleshooting pointed to having no spark so I swapped my Pertronix out for the points, but still no spark. I pride myself on being prepared for most field repairs, but I couldn't get the truck running and ended up being towed home. After a month of sitting in the garage, I finally had a chance to look into the problem.
So, the Pertronix is definitely dead (I'll spare you the details of the diagnosis). With the points installed, I get no spark from the coil wire to the engine block when I turn the engine over. I pulled the cap of to make sure the points are closing properly. When I pulled the cap, the points were open. Using the hand crank, I turned the engine over. When the points closed, the spring that holds the points closed began to glow bright orange. All the plastic parts & wires attached to the points melted and then caught fire before I had a chance to turn off the ignition.
I've traced all the wires in the ignition circuit & everything checks out with the green bible. I have my original coil & a new coil. With the ignition leads attached I measure 12V between positive & negative of the coil & measure 3.5Ohms between positive & negative with no wires attached. I plan to order two new sets of points tomorrow, but I'm still stumped at this point. Does anyone have any thoughts? Thanks.
R/,
Lew
R/,
Lew
