Distributor, coil, Electronic Ignition Question
  • bearcrawl
    • May 2008
    • 60
    Truck is a 66' 2a that has been switched to Negative Earth by the previous owner (who was know to screw stuff up). I recently removed the old electronic ignition (crane type, externally mounted, works fine, if you want it get ahold of me. I just wanted the engine bay to appear more original) and replaced it with a Pertronix. I read something saying that when switching to negative earth you must switch the leads @ the coil to avoid getting a weak spark. Right now I have the white wire from the factory harness AND the positive wire from the Pertronix going to the coil POSITIVE. Coil Negative goes to the Pertronix negative. Runs fine I am just curious if I am getting a weak spark and am not aware of it. Would the electronic ignition solve that by itself? Can I measure the coil output with a multimeter? If so what am I looking for?
    Thanks again in advance.
    Nor-Cal
    67' 88"
  • graniterover
    • 167
    <<Can I measure the coil output with a multimeter?>>
    You can test the coil with a multimeter, but I'm not sure you want to measure the output with one.
    • scott
      • 1226
      i could never tell the difference. when it wasn't running i switch the to low volt coil wire arond, still no start. once out of curiosity i switch 'em when it was running...well i shut it down 1st then switch 'em, started it up and couldn't tell the difference
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
