Originally posted by Triumph
Couple o' things for ya....
A) You can switch from 18" to 16" rims, no problem, just find a suitable tire so the rev-count of the tire is as close as to what you've taken off (unless, you're wanting a taller tire for more ground clearance while at it).
B) In locating 16" rims, make sure that you are sticking with DII rims. You'll quickly find that a lot of the 16" Rover rims you find are the 5-6.5" bolt pattern, which are for RRC's, Defenders, Disco I's, Series. The Freelanders, DII's, P38's and RR3's use a smaller diameter bolt circle in the bolt pattern.
C) Just a hunch here.... since you posted this question on the Series board, you were probably thinking that it is for Series II Discoveries. You will find more help on the Discovery II board, as this particular board is for the old Series Land Rovers from 1948 to 1982 (the old ones w/ the tires up on the hood). (er, tyre on the bonnet.)
Good luck,
