I started to troubleshoot a bad miss on my 67 IIa 2.25 petrol today. The number 1 cylinder (closest to radiator?) was not firing. When I did a compression check on this cylinder I got a zero reading
. I popped off the valve cover and noticed right off that a pushrod (2nd valve in from front) had come disconnected from the rocker. The pushrod still was straight so I compressed the valve and reinserted. After setting the gap I checked the compression again and this time got 30 lbs. All other cylinders read at or near 130.
I know this engine was rebuilt less than 5K ago. At that time the head was redone to support unleaded gas. I believe the prior owner did the lower half also. Any ideas as to next steps? Pull the head? Are there other tests to narrow the problem to the valve? Thanks!
Dave
Dave
