Oil Pressure - 2.25 Ltr Engine
  • pvkd
    • Jan 2007
    • 118
    What should one expect for oil pressure at idle and at speed?
    Paul
    1995 LWB Range Rover Classic
    2001 P38A Range Rover
  • bearcrawl
    • May 2008
    • 60
    warm, @ idle, I am about 20-25. Running I am a pretty consistent 45
    Nor-Cal
    67' 88"
    • gudjeon
      • 613
      I second what he said^^^^^. I use a 15w40. In the winter, I use 10w30. Running the 10w30 in warmer weather, causes the idle pressure to go to about 5-10 psi.
      • Eric W S
        • 609
        Right about 20 idle, almost 50-60 running.
        EwS
        • Jim-ME
          • 1379
          Warm (but with an oil cooler) 25-30 at idle. At speeds over 2000 rpm 60 running 20W-50 summer 10W-30 in the winter.
          Jim
          • badvibes
            • Mar 2007
            • 364
            Right around 20 at idle, 50 or a little better at driving RPMs. 20W-50 all the time.
            Jeff
            1991 Range Rover Hunter
