Brake/Clutch Reservoir Leaking - HELP!
  • pvkd
    • 118
    I am trying to get ready to attend the National Rally in Moab next weekend and I have just discovered that the 'bake bean' can reservoir sprung a leak. The nut on the bottom as been disturbed and will not tighten.
    Any ideas or a spares?
    I am in Thousand Oaks CA.
    Paul
    1971 109 Safari Wagon (1 ton chassis)
    1995 LWB Range Rover Classic
    1997 Defender 90 (repaired at last)
    2001 P38A Range Rover
    Take it apart and have a look at it. Maybe it can be fixed, maybe it can't depending on what's wrong. It's short time to take a look. If you need one, I'm sure our host can hook you up.
    Jason T.
    • pvkd
      • 118
      PROBLEM FIXED !!
      I forgot about the nut on the inside of the can. I found a socket that fit it and was able to tighten it to fix the leak.
      Thank you
      Paul
