Series Rovers w/ D90 fender flares....
  • NC Rover
    • Dec 2007
    • 288
    Looking for some pics of Series rovers with D90 fender flares. My rover has the D90 axles so the wheels stand just slightly outside of the fenders. Rocks tend to sling up the side of the rover so I'm considering the fender flare mod. Any tips or suggestions on what modifications need to be done as well as where to find a set?
    Here is the rover in question....
    1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
  • graniterover
    • 167
    I still have those flares man! They are in my garage now.
    • CliftonRover
      • Mar 2007
      • 351
      I hav disco axles on my 109 and I choose to just use wheels with very little back spacing. they are stock rover wheels I believe mine are early 60's 88 wheels. 16" by the way
      • msggunny
        • 621
        Check out Terri Ann's site, i believe you have to have defender fenders in the front for the defender flares to work.
        One of our sponsors competitors has some especially for the series. Starts with a D and ends with a P (has an "a" in the middle)
        Or at least they did.
        You could possibly get the defender flares and cut your fenders too, if you wanted to go that route.
        04 DII
        08 D3 (LR3)
        • enovey
          • 48
          If you want pictures of series rovers with D-90 flares, check out East Coast Rover's site:
          • Leslie
            • 613
            The Defender and Series have different arch shapes. There are Defender-like flares made for Series, FWIW.....
            -L
            '72 SIII SW 88"
            '60 SII 88" RHD
            • Jim-ME
              • 1379
              There are some arches on Ebay-UK for a Series Rover
              Jim
              • greenmeanie
                • 1358
                IMO the immitation flares shaped to fit series arches look pretty cheesy but each to his own. If you are going to do it I would use the true defender items and trim the wings to fit. I think the best example I've seen is on KevinNY's truck seen here.
                My old landy LARA. I miss her lots... Good eye-candy for the winter thou. I have loved looking at all the pics :wings:
                An alternative would be to rivet a strip of rubber to the wheel arch lip so that it extends out by about 1 - 2". It is far more subtle if you want to maintain the series look and works quite well.
                Cheers
                Gregor
                • aleshanic
                  • Sep 2008
                  • 4
                  Lights
                  Where did you get your lightd from? Non std? They look better than mine
                  • Tdi Guy
                    • 45
                    What size tires are those on your truck?
                    1984 D-90 Tdi
                    71 IIa 88 Perkins Prima Powered
                    1995 D-90 SW Tdi #413
                    No Gas burner Here............
                    Randy
                    • NC Rover
                      • Dec 2007
                      • 288
                      Cheers
                      Gregor
                      Yeah thats what I plan on doing...no immatation. Thats the only problem is that I really do like the original series look so I've been brainstorming for some different ideas.
                      Thanks again for all of the suggestions!
