I hope someone can help me with this problem. I just finished rebuilding a 2.25 petrol engine out of an S3. I've put about 400 miles on it driving on flat land, not over 50 mph. Lots of power (realatively speaking) but it smokes like a Pensylvania steel mill! It burns about a quart of oil in a hundred miles (10w40). The mechanic keep telling me 'the rings have to set'. This sounds like so much BS. Head was done, new rings, anything I could think of was replaced. What can be causing this? Will it burn this much oil until 'the rings are set'? In Calif. I'm liable to be shot driving an oil burner. Thanks for any input.
New engine trouble
Replacing parts alone will not cure oil burning. Did you hone out the cylinder walls, and check the ring clearance?
Rings do have to seat, but I have become a believer in the technique of flogging the engine out during the break-in to seat the rings rather than running it easy. Also, no syntheic oil for the first 5000 miles.
Someone on here originally posted this link:
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board. -
Note: Some oil burning, especially during the first 1000 miles is normal. My 88 smoked a little until about 200 miles. However, excessive smoke could be another problem besides the rings alone. Your mechanic could have installed the valve stem seals incorrectly, or have damaged one or more of them. You need to isolate the oil buring to a single cylinder if you can. Pull out each spark plug and see if there is a black oily buildup on the tip. If it exists on only one or two plugs, then those are your problem cylinders.
How much smoke are we talking about? James Bond smokescreen? or what?
Is there less smoke or more smoke if you rev the engine?61 II 109" Pickup (Restomod, 350 small block, TR4050)
I thought the Pennsylvania steel mills were all closed. So you should be running pretty clean.
Sorry couldn't resist.
Agree with the others, you don't want to rev the piss out of it 100% of the time but you need to run it at a variety of rpm's. Short bursts of WOT force the rings to expand tight against the cylinder walls and help them bed in.
Originally posted by WalkerI hope someone can help me with this problem. I just finished rebuilding a 2.25 petrol engine out of an S3. I've put about 400 miles on it driving on flat land, not over 50 mph. Lots of power (realatively speaking) but it smokes like a Pensylvania steel mill! It burns about a quart of oil in a hundred miles (10w40). The mechanic keep telling me 'the rings have to set'. This sounds like so much BS. Head was done, new rings, anything I could think of was replaced. What can be causing this? Will it burn this much oil until 'the rings are set'? In Calif. I'm liable to be shot driving an oil burner. Thanks for any input.A Land Rover would never turn up to collect an Oscar. It'd be far too busy doing something important, somewhere, for someone."
Thanks for the info.Yeah, I know the steel mills are shut down. Anyway, cylinders were bored to 20 over with approriate pistons and rings (mechanic says they were "file to fit" whatever that means), new seals, valve guides, valves and seats reground, etc. I'll start looking at the plugs for oil buildup. PCV system is in place and appears to be in good order. Any possibility of pressure buildup in the crankcase causing the engine to suck oil thru the PCV system? Suggested by a 'jeep' friend.Comment
file to fit? gapping the rings? does anybody do that on 2.25's??
if you haven't done a compression test, do one now. engine warm, throttle blocked open. take down the numbers.
Originally posted by WalkerThanks for the info.Yeah, I know the steel mills are shut down. Anyway, cylinders were bored to 20 over with approriate pistons and rings (mechanic says they were "file to fit" whatever that means), new seals, valve guides, valves and seats reground, etc. I'll start looking at the plugs for oil buildup. PCV system is in place and appears to be in good order. Any possibility of pressure buildup in the crankcase causing the engine to suck oil thru the PCV system? Suggested by a 'jeep' friend.A Land Rover would never turn up to collect an Oscar. It'd be far too busy doing something important, somewhere, for someone."
Thanks for the suggestions. So far this is what I've found: Compression leak-down test is 6-7% in each cylinder. Pulled the PCV vale and replaced it with an in-line Japanese model and oil consumption has dropped to almost nil. Still get a white cloud on occassion but nothing like before. Thanks for all the suggestions, folks.Comment
Try disconnecting all the PCV system and sealing up all holes except the valve cover. If smoke dissapears completely then there you go. Wether or no to run a PCV system has been hotly debated in a past thread and it's mostly an environmental thing.'73 SIII 88"
Turner 8:1 Engine
NRP Exhaust
Roverdrive
RM Parabolics
OME Shocks
Warn 8274
Pangolin4X4 bumperComment
