My series has developed a couple of faults but I am unsure whether they are connected - any advice would be appreciated.
The engine starts up first time even when cold and then it starts to idle irratically then sorts itself out and idles fine. When driving she runs fine but will stall when I stop - I have also noticed that the clutch has started to feel spongy and will momentarily stick down and then come up slowly - could these problems be connected or is it coincidence that they have started about the same time. The only thing that I have done is fitted a battery cut off switch so that I can turn the power off to the battery when not running her for a while. Your thoughts would be appreciated.
Russ
Russ
