I have a Dormobile with a Robert Davis 3 litre engine. I purchased a Series III Gearbox and High Ratio transfer case from RN. Since the outset, the gearbox when in 4th gear will slide out when the throttle is feathered, usually while going downhill. It just gently slides out. You can hold the gearlever and it will stay in, without any effort. All other gears work fine. It shifts fine and is not noisy at all. I really don't want to pull the whole shabang out again....any suggestions? weak spring in the detent.
Thanks
Jim
Thanks
Jim
