Creating the new rearbumper is one of the most intense things I had to do. Trying to make it fit perfectly, after mounting everything finding out not everything fits perfectly... Getting it right after all.
Have to skip some photo's here due to exeeding limits, but this was the testdrive the other week. Right now I'm having a charging-problem. I thing my regulator is busted. I'm also waiting for some parts being chalvanised and arriving this tuesday. The headlight-switch is being revised and when that's all complete I can finally drive legally. I had the bulkhead all blasted and powdercoated. I decided to leave the outside as it was. You can count the years in the layers of paint blistering off, which I think is kind of unique. Maybe some day I'll paint the whole thing, I don't know. For now I just want to drive it, that's all.
I got the swivel housings installed, but I still need to set the pre-load and install the seals:
I noticed that the new 'normal' bump stops that I installed did not match the originals. The originals are almost 1" taller (they sit on a boxed-in steel section). I removed them from the original chassis, then sandblasted & painted them. Here they are:
As you can see, I had to get a little creative when mounting the original front bump stops on the new chassis. The mounts on the new chassis are much too high for some reason. Compare the above picture to the original chassis and you'll see what I mean:
Got my air cleaner support back from the powder coater:
I also just received about 15 pounds of hardware back from being cadmium plated. I was finally able to re-assemble the pintle hitch and get it installed:
I assume the locking bolt for the lower part of the pintle was there to begin with. Mine is missing and I don't think that is a part I could find separate. Just curious really.
Hey what's taking you so long? I'm already driving around in mine! I'm kinda curious for your latest progression. I'm probably going to start on my dads
Lightweight some time this year, and we're gonna tear it apart and rebuild it somewhat like you're doing right now.
All rust repairs on the bulkhead are now done. I test fit the bulkhead on the new chassis and it fit! Now I'll temporarily mount the pedal boxes, run the new brake & clutch lines, then take it all apart for final sandblast & paint.
