On a 109, how does the under seat gas cap unscrew? Mine only turns 1/8 of a turn before stopping on something. Just wanted to ask before I force and break something. Thanks.
Auxiliary Fuel Tank Cap
the cap on one of my tanks also tends to stick when trying to open it. I turn it until it sticks and then try and pry it off ( with my hand) until it makes a popping sound. Then turn it the rest of the way and it should come right off. my 2 centsComment
The aux. tank cap, or twin military tanks' cap, is a three prong type. It sounds like it may have been forced on or off, and the prongs are out of position (or the ramps where the cap engages the fill tube are deformed). You might try a little upward, or downward pressure, as you turn it anti-clockwise to see if it pops off the obstruction.
Once you get it off, check that all three prongs are OK and the ramps are aligned properly. I had to fine tune the ramps on my fill tubes to get them to work.
Regards,Tom P.
1965 exMoD 109
1995 RRC LWB w/EASComment
