WTB: SIII Dash Top
  • Apis Mellifera
    • 386
    WTB: SIII Dash Top
    Condition not that important, but needs to have some of the foam left. I'm thinking about making a vacuum forming machine to make a dash cover for SIIIs. I can't believe Coverlay doesn't make one.
  • Leslie
    • 613
    FWIW.......
    W/ my SIII, I bought black marine-grade vinyl at a local fabric shop. Used apolstery adhesive, wrapped the thing.... the back end is hidden against the bulkhead, and the ends are hidden by the end caps. There was a bit of a chip out of the padding where the old vinyl was cracked, that I filled w/ kitty-hair first.
    Where I would have liked a vacuum machine was on the lower dash, not the upper.... the corners are a bit complex, and the marine-grade vinyl I had was backed.... if I had backless vinyl and more heat, or vacuum, it would have been cleaner.... as it was, I had to pick a spot for a seam.
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
      I agree- someone needs to figure out a way to replace the black vinyl on the SIII windshield wiper motor cover.
      • Apis Mellifera
        • 386
        My lowers are intact, but maybe I'll (try to) make those too. I just want an extra top for sake of ease of the experiment. The lowers come off pretty easy, the wiper motor cover anyway.
        I have a Coverlay on my MGB and did the vinyl on a Midget I had. It would be faster and easier to use a Coverlay-type thing.
        • Leslie
          • 613
          I recovered the lower dash and the wiper motor cover, and the only way I could do it w/ the vinyl I found was to have a short vertical seam from that 3-way facet, straight up from there. I now need to find a way to "neaten up" that seam. The upper dash was a piece of cake by comparison.
          -L
          '72 SIII SW 88"
          '60 SII 88" RHD
          • dmurrell
            • 32
            Has anyone tried Just Dashes to see if they'd do it?
            We specialize in Classic Car Interior Restoration more than just the dash pads and instrument clusters. Check our works to know what other parts we restore.
            I'm starting my project and was thinking they might be a good source for refurbishing my dash .....
