I have a series 2a 88'' wondering if theres any lift kits out there. thanks
are there any lift kits out there
I did'nt think you could lift it to high cause of the front drive shaft issue with the cross member. I've searched this before and all I found was using a good set of parabolic springs.
You could gain 1 1/2 inches if you swith from stock 29"tires to 32" tires.1972 NAS Series 88 SWComment
I installed new stock springs and 235/85/16 tires (basically 32s) and the truck rides high enough to get in and (more importantly) out of alot of trouble.Originally posted by LH DriveIYou could gain 1 1/2 inches if you swith from stock 29"tires to 32" tires.------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
-- http://www.youtube.com/barnfind88 --Comment
if parabolics are a "no can do" for you, trailmaster makes an add a leaf that adds 2 inches. http://www.trailmastersuspension.com...s/addaleaf.htm
however i dont know anyone who has gone this route though------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
You could go with a SOA setup. This will require some custom work of course. http://www.4wdandsportutility.com/fe...ver/index.htmlStacy
Motta S.A. ItalyComment
Iceland hillclimb? Good schtuff Ike.Comment
