i hear that the bore of the 2.25 and 2.5 are the same. it's the thow that's the difference. anyone ever put a 2.5 crank and rods in a 2.25? there's a company, in england i think, that sell/does mods to old rover motors that push the hp up to over 100. i've been to there site before but can't find it now. do any of you guys know who i'm thinking of?
morph'n a 2.25 to a 2.5
Automotive Comp Remanufacturing or ACR are who you are probably thinking of. They claim 112hp but for the kind of money they want to get you there you could put in a comparable engine for half the price.Comment
Originally posted by svenThe 2.5 crank uses 5 main bearings. Yours is only 3 bearing. So I dont think that will work.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
yes some 2.25's are 5mb. Once in a while you run across them but the odds are that yours is a 3mb unless it was replaced in the last 25 years or so.Comment
Most would probably pick a 5mb over a 3mb, but, I'd take the 3mb myself..... yes, 5 main bearings are 'better', but, they didn't do it because it was, they did it because they thinned out the walls (hence the reason the 5mb has the casting ribs on the side of the block).... the 3mb should actually be a bit stronger.-L
'72 SIII SW 88"
'60 SII 88" RHDComment
Ive redone the head on my friends 2.5 hybrid series. We also fit a new weber 32/34 on it that took forever to find. That carb was big bucks too and is specific for the 2.5.
After all the headwork, new carb, and NRP exhaust the truck ran and drove sweet. But honestly, the power is very similar to my 2.25. If I were to redo my 2.25 (which I will have to do) I would just do it stock.99 D1
73 Series III 88"
95 RRC LWBComment
I had an ACR engine in the lightweight when I got it but had to pull it when the knocking got bad and oil wouldn't stay in. The thing ran great with it but only got about 10 mpg and certainly was getting long in the tooth before the swap.
Since going back to a 2.25 that I had sitting around, I can tell you that my mileage is at least 50% better but the top end just isn't there. But the best part is that the 2.25 purrs with that sewing machine perfection.I just couldn't manage that with the ACR get up.
Not sure I'd spend the cash for a full on ACR kit myself unless I really wanted to keep the stock appearance. Although powerful, it felt like it was abusing the standard block (which in this case happened to be a 2.5 diesel block).
By the way, the ACR did get me past 90 mph (well +85 on 33"s) once or twice and I swear there was still more in it. But in all honesty, that really wasn't the best thing to be doing...Comment
Originally posted by OkarThanks for the info Tim, I have a 2.25 diesel 109 pick up, was wondering whether to stay at 2.25 or go 2.5
As an aside, I believe the 200 bottom end is a very close relative to the 2.5 block. Which of course is a kissing cousin to the 2.25 5 bearing motor. The differences between the 2.5 and the 200 are mostly in the top end so you can draw your own conclusions.
Of course someone is going to prove me wrong on that one... and I hope it's with info more than the side webbing on the block.
Originally posted by OkarI guess if i want to go fast, I'll do so in the Audi....
I think the best thing you can do while the motor is out is to add in some sound deadening on the bulkhead. It's not so much that a well tuned 2.25 petrol is working so hard to keep up with the highway but rather the sound it makes while doing so is horrendous. And without some kind of sound barrier, you hear everything.
Not too sure about a 2.25 diesel and power but if you need some cheap power (and you don't care about the motor's long term life span any more) you could always add a propane injection get up. Woo Hoo!Comment
Propane isn't very useful on a NA diesel vs. a turbo...
I thinkt he best bet is to accept it for what it is and enjoy it. It is a time machine- taking you back to a more serene- slower, and noisy-smelly time.Comment
Originally posted by svenIve redone the head on my friends 2.5 hybrid series. We also fit a new weber 32/34 on it that took forever to find. That carb was big bucks too and is specific for the 2.5.
After all the headwork, new carb, and NRP exhaust the truck ran and drove sweet. But honestly, the power is very similar to my 2.25. If I were to redo my 2.25 (which I will have to do) I would just do it stock.1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|Comment
parts are in! my old head had some repaired cracks so i went with a rebuilt 7:1 shaved to give a 8.5:1, a 2.5 cam and .060 over pistons. the only siezed parts were the MBs so those and the rod bearings are being replaced with .010 overs. shoud be picking it up in a couple days. the old weber 34/36 dgv will go back on and i have a 1.75" exhaust. i plan on having it dyno'd so i'll let you all know what the bhp turns out to be'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
Originally posted by scottparts are in! my old head had some repaired cracks so i went with a rebuilt 7:1 shaved to give a 8.5:1, a 2.5 cam and .060 over pistons. the only siezed parts were the MBs so those and the rod bearings are being replaced with .010 overs. shoud be picking it up in a couple days. the old weber 34/36 dgv will go back on and i have a 1.75" exhaust. i plan on having it dyno'd so i'll let you all know what the bhp turns out to be1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|Comment
Originally posted by NC RoverGot any pics you could post up? I want to see some pics of your carb. I've having some "issues" with mine.'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
