I have a 65' 88 that is getting ready for inspection, however my dad said that he thinks that the front turn signals have to be yellow. i thought i've seen other series with clear glass though. when i did the restoration i replaced both turn signal and running lights with the clear low profile glass. If anyone knows if i can get away with these clear lenses that would be great. also i live in pa if its a state thing. thank you for any input
Do turns signals have to be amber?
Amber bulb might work
BGGB,
I don't know about your state law, but I have amber bulbs behind the clear glass turn signal lens, this is not really noticeable until it is blinking.
Of course on mine the signal is the large domed not the flat one, just goes to prove each LR is a little different.
John -
You will be fine. Vehicles manufactured prior to the change from Red(Rear) and Clear (front) were not required to retrofitted with amber lenses on the indicators. It doesn't matter whether the vehicle was continuously registered, or off the road, and being re-registered, as you're doing.Comment
Two things....
1) If it were me, I'd just bring it down to get it inspected. I doubt that they'll fail the truck because the front turn signals aren't amber. If they do, you're taking it to the wrong place to get it inspected. Plus, it's an easy fix using the amber bulbs mentioned in a previous post.
and...
2) I endeavor to get to a point where the color of the turn signas lenses was my greatest pre-inspection concern. Unfortunately, my worries are more along the lines of an iffy outrigger and the large oil slick I seem to be parked over, no matter where I park.--Mark
Amber
It will really depend on what state you live in and how fussy they are about the car being equipped consistent with its year of manufacture. My experiences are only in Vermont and Maine, where it seemed only to be important that the turn signal actually worked. I doubt that most inspection stations even have information on such old models.
As noted above, however, it's easy to get an amber bulb if you find yourself in a problem.
Good luck with inspection - it always causes some heartache.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
Originally posted by Jeff AronsonIt will really depend on what state you live in and how fussy they are about the car being equipped consistent with its year of manufacture. My experiences are only in Vermont and Maine, where it seemed only to be important that the turn signal actually worked. I doubt that most inspection stations even have information on such old models. Jeff
YMMV, AndrewAndrew
'63 SIIA 88" SW
Rover Pics: http://www.flickr.com/photos/skunkal...7610584998247/Comment
also i live in pa
however, I decided to just get antique plates and not worry about inspections or yearly registrations.
it makes it much easier.
JaimeOne Life Live ItComment
Originally posted by BGGBwhen i did the restoration i replaced both turn signal and running lights with the clear low profile glass.
While on safety, the amber lights are easier to see.-
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
