2.5L Weber Carb Question (pics)....
  • NC Rover
    • Dec 2007
    • 288
    So I came across a part on the carb that was loose. Unscrewed it and realized that the previous owner had put a lot of white sealant tape to keep it in as the treads don't match...the removed part (with male end) threads are smaller in circumference than the carb (female end). **Note in the pictures below, I have already removed the old white sealant tape from the threads and cleaned the needle.
    I've had problems lately with the rover running too rich and sputtering...like its getting too much air, however I cannot find an air mixture screw anywhere on the exterior of the carb to adjust while the engine is running.
    Can anyone tell me what part this is and what it effects? When I first exposed the needle, it had grey gunk crusted up all over it. I cleaned the needle really good as well as inside the removed part.
    You can see the needle inside that is spring loaded. Does this automatically adjust the air misture? Sorry for the noob questions. Learning as I go. Just re-adjusted all the valves on my own so I'm coming along.
  • Andrew IIA
    • Feb 2008
    • 327
    Your carb looks a lot like my Weber 32/34 DMTL on my IIA. I think the gizmo is a spark arrestor. If I disconnect mine it will run like crap and/or stall. I'll take look at mine afer work today and get back to you. There is a difficult-to-find adjustment screw, but I can't remember if it adjusts mixture or slow-idle speed. I'll report on that too.
    Best regards, Andrew
    Andrew
    '63 SIIA 88" SW
    • sven
      • 174
      That is definitely a 32/34 DMTL.
      Mixture screw is facing the front of the truck. If you're looking at it, it would be all the way on the right side at the base. You need a tiny/thin flathead screwdriver to adjust.
      99 D1
      73 Series III 88"
      95 RRC LWB
      • NC Rover
        • Dec 2007
        • 288
        awesome. Thank you. I will look for it tonight. I'm still curious as to why the threads don't match (male end is way smaller in circumference than the female end) on the part I removed....
        • NC Rover
          • Dec 2007
          • 288
          The 4th picture down from the top is a picture of the carb facing the front of the vehicle. Is the air mixture screw visiable in the picture? I swear I looked this carb over and couldn't find an air mixture screw.
          Also, does anyone have a diagram of this particular carb?
          • sven
            • 174
            Its below that orange wire. You cant see it in the pic but the screw is recessed into the base of the carb.
            I attaced a pdf for ya, hope that helps.
            99 D1
            73 Series III 88"
            95 RRC LWB
            • Andrew IIA
              • Feb 2008
              • 327
              Here the pic to go with Sven's diagram. Its sort of hidden; slot-head screw. Hmm.... your carb's a lot cleaner than mine .
              Thanks for the diagram Sven, I didn't have a copy of that.
              '63 SIIA 88"
              Andrew
              '63 SIIA 88" SW
              • NC Rover
                • Dec 2007
                • 288
                Thanks for the diagram. That helps. However I'm not seeing the part I removed in the diagram...the part that is right next to the fuel line entrance.
                I'm going to try and clean the jets in the carb as well as adjust that screw and see what I can come up with.
                • NC Rover
                  • Dec 2007
                  • 288
                  '63 SIIA 88"
                  Ok the big thing in the top left of your picture with the wire coming out of it....what is the official name for this part of the Carb and what is its function/purpose?
                  For some reason mine will not stay in..it keeps falling out. Is it suppose to screw in place?
                  • Andrew IIA
                    • Feb 2008
                    • 327
                    Hmm. Don't know the name for that and I agree its not in the diagram (we'll call it gizmo for now). the wire runs from the gizmo to the solenoid for the fuel shut-off valve, a safety thing. I think that if there's a fire (or fuel overflow ?) the gizmo's internal thingy moves/slides and disrupts the electrical contact with the fuel shut-off solenoid (thus activating it). I don't know what holds mine in place as I've never had to remove it.
                    Let us know what you learn
                    Andrew
                    Andrew
                    '63 SIIA 88" SW
                    • sven
                      • 174
                      The 32/34 that I worked on didnt have those solenoids.
                      Contact these guys for any weber parts. This was the only place in the US that had brand new 32/34 webers. They also carry all the parts, jets, kits, etc.
                      Weber carburetor,Intake Manifolds, Conversion Kits, Air Filters, Linkages,Everything you need for your new or vintage ride!
                      99 D1
                      73 Series III 88"
                      95 RRC LWB
                      • NC Rover
                        • Dec 2007
                        • 288
                        http://www.piercemanifolds.com/
                        I checked this site and didn't see any 32/34 DMTL. I only saw 32/36. Did you say a brand new one was listed on the site? Any idea how much they run?
                        • NC Rover
                          • Dec 2007
                          • 288
                          I meant to ask....do you guys know which jets go to which hole since they are all different? I'm wondering if the previous owner took them out and replaced them in the wrong order? How would I know if they are in the wrong order? I remember someone mentioning about certain numbers on the sides of the jets. Any idea which numbered jets go to which corner of the carb?
                          EDIT: I took out each jet one by one from front to back and cleaned them. Also wrote down the number on each:
                          Front to back:
                          Jet 1 = 52
                          Jet 2 = F-30
                          Jet 3 = F-39
                          Jet 4 = 6U
                          Anyone know if these are in the correct order?
                          • Terrys
                            • May 2007
                            • 1382
                            Andrew
                            The solinoid is an anti-detonation valve. It's intended purpose is to prevent run-on after the key is shut off. I hate that carb. I have never seen one jetted correctly for a 2 1/4 LR engine.
                            • Rineheitzgabot
                              • Jun 2008
                              • 386
                              Mr. and Mrs. Pierce were the previous owners of my Bugeye. It's actually shown in their gallery on their website (on page 5, if your interested ).
                              This may be why mine runs so damn good. I think the Pierce people understand the Weber and all it's idiosynchrasies, pretty well.
                              Again, I love me Weber.
                              "I can't believe I'm sitting here, completely surrounded by no beer!" -Onslow
