So I've been getting a lot of blow by out of the 2.25 lately and on a recent trip the problem became overwhelming. Was pulling a Sankey on the highway and if I pushed the truck either up a hill or up to about 60-65 smoke started filling the cabin at an alarming rate.
For quite some time I've had this problem it seems because the oil filler is just soaked with oil dripping down out of the vents. Been cleaned a few times but it just gets covered again in sort time.
What I'm wondering is if that stuff you see (usually in a silvery tin) which claims to be some sort of rebuild in a can could be of any use. You add it to the crank case and let it do it's thing until the next time you change the oil...
I'm avoiding any major work on the truck as the timing isn't right. I also don't have a pressure gauge handy so checking the compression or a leak down test would be a bit of a hassle.
I should note that on a compression check I did a few months ago, #1 cylinder was sadly low. Something like 40 or 60 psi but the truck had been sitting for some weeks so the cylinders were probably completely dry at the time of the test. The rest of the cylinders varied but were below 100 psi if memory serves.
Maybe there isn't much that a tin will do for me here but I'm wondering if anyone else has tried that stuff. Wish I could remember the name of it...
Kind of hoping for something that can score up the cylinders and clean up the rings without actually taking it apart to do it.
Oh yeah. It's a SII block with a breather on the valve cover as well as the filler pipe. Oil only comes out the filler pipe though so it's got to be excess pressure in the crank case. Right?
