While lots of owners have positive experiences with Petronix and similar electronic distributors, I've not shared those good results and I've helped other owners on the side of the road whose distributors failed them.
So, if you ask around, I'll bet someone has an old points distributor they could send to you. If you check and gap the points, and then time the car, and then run the car, you can either eliminate or confirm the distributor as the problem.
At the British Invasion a decade ago, one enthusiast joined a crew of friends doing an overnight valve job in the belief that his poorly running car suffered from a burned valve. When he fired up the car the next morning, it ran no better. A skeptic of the original plan, a man who really knows auto electrics, again offered up the spare distributor he carries with him. The car hummed like a turbine. The problem was inside the distributor all along.
Jeff
Jeff
