Originally posted by thixon
Fuel Tank Vent
Originally posted by sayersI have an all orginal 88, it has the charcoal canister and all piping or tubes, it also has the orgin. cap, I was thinking just not fill or try to fill it up all the way when the pump kicks off the first time. I am thinking that the tube may be off or cracked, maybe need a new hose to the expansion tank, I'll have to investigate further. thanks
If it were me, I'd do exactly what you mention and look for leaks. You can just stop filling the tank full to stop the leaking, but if you rolled while wheeling you could start a fire. Thats always a possibility anyway, but why add another variable to the equation?
Remember, there's no reason you have to run with all that installed. You could just rip it out, get a vented cap, and cap off the elbow in the top of the tank that ran to the venting system.Travis
'66 IIa 88Comment
Remember, there's no reason you have to run with all that installed. You could just rip it out, get a vented cap, and cap off the elbow in the top of the tank that ran to the venting system.Comment
There are caps that are vented and unvented. Series II-A's have the overflow and need the vented cap. It makes sense that the Series III would be a non-vented cap; the whole idea was to trap the vapor in the system, and thus the charcol canister.
I fill the tank slowly and pay attention to it's likely amount needed to fill. I haven't had an overflow since then. I wonder if the military dual tanks create different dynamics.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
