I'm sure the question's been answered before, but are there any dos and don'ts for getting paint off galvanized trim? I've got some generic gel stripper I was going to try, and the paint is already peeling and flaking pretty bad so I'm hoping it'll be relatively easy going, but advice is appreciated.
Stripping galvanized parts
Superstator,
Try masking tape if its flaking.
After putting blue painters tape on my 'silver painted' trim for a parade I found that when I pulled it off most of the flaking paint came right off. So now I am just using tape to pull it off and will probably use something like Citristrip to take the remainder off or wait until the rest peels.
John -
i used some stripper from yall'mart, it was in a spray can, and didnt hurt the trim in any way. the paint came right off!Comment
I have stripped mine with the aircraft paint remover and everything looks fine. It did not remove any of the galvanizing finish. I did this all before i knew that the galvanziers will actually strip them in a chemical bath before they re-galvanize it.
If you are wanting to have the pieces look "new" again you might think about pulling them all off and having them galvanized again. Its not that expensive to do...mine will be close to $200. However, its a pain to get all the hammer and pop rivets off...and I am sure excited about replacing all the rivets to get them back on (said with sarcasm).
Birmabright Brotherhood
