Originally posted by TedW
Just to clarify the prevous posts: A "rivet set" is not a set of rivets, but the metal rod that plugs into the rivet gun and has a dished end that fits atop the domed rivet head and drives the rivet. It is (mis)labeled "TOOL" in the drawings I made in the last few posts. A rivet set is sized according to the size and type of rivet being used. Using one that is too deep for the rivet (labeled "INCORRECT" in the previous post's diagram) will cold work the surrounding metal, fatiguing it and may also ding it up.
The "bucktail" is the end of the rivet that is flattened or squashed during rivet driving.
Out of curiosity, are you using an air hammer or a rivet gun? They are similar looking but very different in function. An air hammer probably won't have the correct stroke or frequency of blows. Good luck controlling an air hammer in a riveting operation. I suppose it can be done, but it'll look like you did it blindfolded because the air hammer will probably come off the rivet and ding up the surrounding area and rivet head.
I recommend 1) Practicing in some scrap metal first and 2) using 2 people do do this job; You can focus your attention on getting the bucking bar flat and then ding the heck out of the panel with the riveter or you can concentrate on controlling the riveter and end up with a lopsided bucktail.
