Last year the 88 did not pass inspection due to leaky hub seals. The brakes were coated/soaked in 90W. I replaced all the seals and one race (the only one that had any wear/corrosion.) At the same time I replace the brake cylinders, shoes and flex hoses.
Today I replaced the master brake cylinder. When I went to go bleed the brakes I found both passenger brakes soaked in oil again! The worst one was the one I replaced the seal and race (right/rear.)
Right rear: I don't think I put any sealant under the race, could this be my problem?
Right front: I guess I should have replaced the race along with the seal?
Or am I missing something else?
Of course the 88 is out of inspection and I need to get it on the road so I can replace the heater core and blower in the Rangie. Maybe I'll get to it by spring.
Regards,
Larry M.
'72 IIa 88"
'94 RRC SWB
Regards,
Larry M.
'72 IIa 88"
'94 RRC SWB
